Welcome to TFP.
Read
ABCs of Pool Water Chemistry and
FC/CYA Levels
It is not clear how much chemicals you added and in what time frame.
FC is most critical to prevent algae growth. Work on that first.
With adding MA you will lower both pH and TA. Don't go too low on your pH. Monitor the pH as you can deal with the TA over time.
You don't indicate if you have a SWG or use liq. Chlorine to sanitize. Your CYA target states 30-60 (based on how you set up your pool in Pool Math app) and you are at 30 so you do not need to add much stabilizer to move it a little. Best to do it in stages so you don't overshoot your target. A lower CYA means you may consume a little more Chlorine but that is better than overshooting the CYA and having to drain part of your pool water to lower CYA.
To help share your Pool Math logs, go to Settings (the gear icon) then move to bottom and under Sharing slide the button to ON to "Link from TroubleFreePool.com user profile" This way we can see your test results without you having to screen shot them (but that is still OK). If you log your chemical additions then we can see what you added and when to provide you recommendations on next steps.
Keep us informed and others will chime in.
