I know this is likely posted in a few different areas so please point me in the right direction if it saves everyone the headache. Apologies in advance. I have tried searching multiple places and don't seem to get a clear answer. Is "opening a pool" the same the for the very first time as it is if it were the 4th or 5th time?
This is my very first go at this... and want to make sure I get things off and running correctly.
We have finished construction of the saltwater aurora AGP 15x30x54 oval pool. It's mostly resin. I believe there is about 12,000 gallons in the pool. I had a water truck deliver two truckloads of water several days ago - and topped the remaining off with my well.
The water has been sitting for about 6 days untreated... my grandfather passed away recently and the situation has made things challenging to stay on top of the pool opening. I'm dedicating much of tomorrow to get things right!
Steps for Success? Please let me know I have this right:
1) Pool has been filled to about halfway on the skimmer opening.
2) Pump has been hooked up and is ready to turn on. I primed the pump today as I was going to get that on but other business pulled me away. I will power this up tomorrow and get this on.
3)Test for Alkalinity (looking for 80-120 ppm)
4) Once alkalinity is in good order- adjust PH (looking for 7.2-7.6)
5) Once PH is good - chlorine will need to be between 1 to 3 ppm
6) Then CYA - looking for 50-80ppm
7) Once the above is good to go - I start adding salt
8) When salt has been added (believe I'm looking for close to 3200ppm per the manufacturers recommendations) and up to that 3200 mark - then I can turn on the SWG
I'll take more pictures of the setup - still have a big decking job that we are working into this project as well!
Also I have downloaded the app - but my SWG is not listed?
I have a Solaxx Retro Jet RJ SWG
Thank you so much for any help and guidance
