1) Keep chlorinating with Liquid Chlorine until the SWCG is up and running. Maintain FC/CYA ratio for your CYA...Link-->
FC/CYA Levels
2) Add salt, but TEST YOUR CURRENT SALT LEVEL BEFORE ADDING SALT...you may be surprised how much salt you already have.
3) Add salt in increments. Use K1766 salt test kit. Use a speed stir to get accurate results. If you don't have speed stir or K1766, order them today.
4) Make sure your SWCG is OFF while you add salt and for 24-48 hours after dissolving salt. Run your pump to make sure it is mixed.
5) When you hit your salt target (SWCG Manual target using K1766 results), fire that bad boy up.
6) Adjust your pump runtime and SWCG %, using pool math to match your daily FC consumption.
7) Sit back and enjoy the Magic!
