Hey everyone,
Thanks for taking the time to read my post. I read a sticky and pool school's article on closing an AGP, but I'm still stuck at a couple of points. I live in east TN, and we're just now hitting some potential freezing temps at night. My water has finally hit the 58-60deg F temps for the last couple of days, and I have maintained shock level per my CYA level for the last couple of days as well. Pool is spotless right now color looks good chems are testing well.
I am just at a loss on how I 'purge' any remaining water from my PVC / pump / filter before I shut her down for the next several months. I am currently in the process of draining the water to 6" below the return jet. I have a Hayward sand filter with the pretty typical valve settings..
I guess the basics of my questions are these: If I set the filter to "Winter" and remove the drain plug, viewing glass, and pressure gauge on the filter-- will that be sufficient to allow water to get out before risk of freezing in the PVC pipes / filter / anywhere. Or I've read that I may need to get myself a shop vac and just blow the heck out of the lines.. maybe from the skimmer intake to purge as much water as possible out of the hardware?
Is it possible to run the pump "dry" for any amount of time to purge lines of residual H2O, or is that a no bueno bad idea?
Thanks for helping a lost individual! I'm ready to get this guy closed so I can learn and focus on my spa for the next couple of months. This community has been an amazing help!
