Hi and thanks for all who post here and will hopefully generously help me. Opened our kidney shaped vinyl liner pool Sunday and added 9x5L jugs of household bleach (assuming this is around 5%), added 1L muriatic acid, am running sand filter 24/7, added the Trol and CYA I had at home. Have a Taylor K-1004 test kit and am using that in conjunction with pool store testing data until I order on amazon to be able to get a better kit. Please recommend one as the strips I have used in the past are useless and the K-1004 is only good for FC, CC, pH and alkalinity. Results from pool store Tuesday night:
FC 1.75
TC 1.75
CC 0
pH 7.5
hardness 151
alkalinity 92
CYA 19
copper iron and phosphate all 0
Added 4 kg Trol, 7kg Cal, 500 g granular CYA yesterday (and will be adding remainder to add total 1.7g kg CYA over 24-28 hrs). There is still a sticky brown sludge on the sides and bottom of the pool that doesn't move with a brush, shallow end is much better but some light brown dust-like dirt remains there also. I added 8x5L jugs household bleach again this morning and tested 2 hours later:
FC at least 10 (test doesn't go beyond 10)
TC even higher
pH 7.6
alkalinity 130
CYA still low which is to be expected as I'm still adding. I am frustrated with the manual vacuum we have for the kidney pool. I am a shorter woman and it is hard to reach the deep end. Any recommendations on a robotic or automatic vacuum would be great. Had what I think is called a creepy crawler in the same pool growing up and it didn't get all areas and broke. Tried a robotic one from Costco a few years ago but it stopped working during the season so returned it and went back to the manual. Not sure if the kidney shape makes it more difficult or what but with the extension pole, I find the vacuuming difficult. Plus I don't know how to get rid of that brown sludge. Am I correct that it is still algae (thus hopefully my addition of chlorine this morning will help kill it)? Dead algae should be white and vacuum-able, correct?
FC 1.75
TC 1.75
CC 0
pH 7.5
hardness 151
alkalinity 92
CYA 19
TC even higher
pH 7.6
alkalinity 130
