Re: First pool. Day two. How can a pool vac be so complicate
X2 on this ... That is if you do have a main drain?
jasonknox said:I would try messing with the valve to see if you can get more suction through the vacuum hose. When I run my pool cleaner I have to adjust my valves so that more suction is diverted to my dedicated suction line. If I don't the pool cleaner does not get enough suction to move.
