This is our first pool build. Most of the equipment is listed in my signature line. Will update if there are any changes to it.
Basic Plan of the pool:
Details:
REBAR - REBAR TO BE #3 (3/8) TIED ON 8" CENTERS. REBAR WILL BE DOUBLED ON WALLS AND ALL BEAMS.
GUNITE - LIMITED LIFETIME WARRANTY. GUNITE IS HAND FORMED AND MAY NOT BE EXACT. WARRANTY DOES NOT INCLUDE SHELL FLOATING OR SHIFTING FROM DRAINING POOL.
BASE OF POOL POURED AT 10" DEEP.
WALLS WILL BE POURED AT 8" THICK.
MAIN BEAMS (UNDER COPING) WILL BE 12" WIDE X 24" DEEP.
PLASTER - STONESCAPES MINIPEBBLE, 10 YEAR WARRANTY. THIS WILL ALLOW THE CUSTOMER TO GET A LONGER LIFE OUT OF THE PLASTER. CUSTOMER CAN CHOOSE 2 DIFFERENT COLORS GIVING YOUR POOL A CUSTOM LOOK AND FEEL!
CONCRETE DECKING - WE WILL POUR 4'' THICK CONCRETE WITH 3/8 REBAR ON 16'' CENTERS. REBAR TIED TO POOL SHELL, VINYL EXPANSION JOINTS AND DECKO DRAINS WILL BE INSTALLED AS NEEDED.
PLUMBING - INSTALLED BY A MASTER PLUMBER. POOL PLUMBING LINES TO 2.5" FOR BETTER FLOW.
SPA:
8’ X 9’
18” RAISED
(2) TRAVERTINE CAP SPILLWAY
(6) JETS
MOSAIC TOE TOUCH TILE
WATER FEATURE WALL:
RAISED GUNITE WALL
LEDGER STONE FRONT
STUCCO TO MATCH PAVERS ON BACK
(3) 18” BRASS SCUPPERS
(3) 24” COLUMNS
4’ firepit: will be a cinderblock frame, ledgerstone face, travertine top cap, a stainless steel fire ring with lava rock and fire glass on top with a manual gas valve.
Details:
NEW POOL CONSTRUCTION - 36’ X 16’ (16,365 GALLONS) |
PERIMETER ~ 116’ |
DEPTHS ARE- 3’ 6”- 6’6” |
SPA:
8’ X 9’
18” RAISED
(6) JETS
WATER FEATURE WALL:
RAISED GUNITE WALL
LEDGER STONE FRONT
(3) 24” COLUMNS
REINSTALL SOD/GRASS UP TO (3) PALLETS (MAX) | ||
REINSTALL WOOD FENCE AT COMPLETION | ||
REPAIR ALL SPRINKLER HEADS IN THE FIELD OF WORK UP TO 3 ZONES (MAX) | ||
WILL PROVIDE STARTUP SCHOOL UPON COMPLETION OF PROJECT SHOWING HOW TO USE THE REMOTE AND EXPLAIN THE EQUIPMENT. POOL CHEMISTRY AND FILTER CLEANING IS NOT A PART OF START UP SCHOOL. 1 MONTH COMPLIMENTARY POOL SERVICE AFTER INITIAL SET UP EMPTY BASKET, VACUUM, BRUSH, CHEMICAL BALANCE
