Good day everyone. What a great resource this forum and site has been overall. Thank you.
I mounted up and wired the Pentair EasyTouch 8p, one body of water, no spa. I have 3 12V pentair lights, a Pentair 011018 IntelliFlo Variable Speed filter pump, a Pentair 011519 WhisperFlo water feature pump (running bubbler in tanning shelf and waterfall), some 12v landscape lighting and the receptacle at the EasyTouch. I think I am good with hooking up the IC40 to the EasyTouch. I wasnt sure how many, what type(i see the inside of panel for manufactuer, just dont know amperage, gfci or not, ect) of breakers to use. I thought I read the lights should be on a double 20AMP GFCI breaker, powering a PX300 ac/dc transformer for all three lights. To power the easytouch panel and the 15amp outdoor receptacle, I would use a normal 15amp breaker, powering the gfci outlet first. Is that correct? What kind do I need for my pumps? One for each? Do I just use flexible conduit for the home runs from the pumps to the easytouch panel?
I also read out there that the 12v lights might not work right with the relays. Any experience out there with this? I saw this and KUDOS to @bdavis466 for this diagram and information on another post. Thanks again!
