Hi all,
This looks to be a great resource I have found on my travels to try to understand how to get my pool into a condition that is swimmable. It is the first time I have owned a pool and it came with the house I purchased around a month ago (and where the pool was covered for winter at the time so may not have been treated for a month or two or more prior to that again). Apologies for the long post although I have no idea what I am doing although happy to give it all a crack and if I can't get it sorted will get one of the pool companies to look at it in due course.
The pool is small saltwater kidney shaped pool approximately 6m long and 3m wide at its widest point (the area is 14.2m2 and I think it varies in depth from about 1.1m to 1.6m from what I can find online). I don't know the make of it although I believe it to be similar to this one: Maxi-Swim Fibreglass Small Swimming Pool | Sapphire Pools
I've tried to work out the volume using online calculators and think it is in the order of 18 to 19 thousand litres.
It is coming to the end of winter in Australia (NSW) so I might be trying to get it ready a little too soon although thought now is as good a time as any
I started with buying some salt and general pool test strips from Bunnings and found them to not be very good. They did report very low chlorine/free chlorine, low alkalinity and high hardness though. From further searching, the Whirlpool forums recommended the Clear Choice Lab test kit for Australia and I have purchased that and just tested it all after it arrived today; it reminded me of high school chemistry.
The test logs are at PoolMath Logs
The pH was actually less than 6.8 although the test range doesn't report lower than 6.8.
I also bought some chlorine pucks from Bunnings and a floating dispenser and put one in a week ago.
About 3 days ago I added 20kg of salt to the pool as the salt test strip I used said it was low. The salt cholrinator control panel is also warning that the salt is low and it is reporting 0 chlorine generation. I tested the salt with the better test kit and it was 3800ppm today. I've added another approximately 6kg of salt which is what the pool math calculator suggested.
I have run the filter the past two days (4 hours the first day and 8 hours today). The salt chlorinator is reporting low salt and not generating any chlorine from what I can tell. I will post some photos tomorrow also. The filter is set to 'filter' although the pressure gauge is showing 0 when running; I tried tapping it like some articles online suggested although still see no pressure reported.
I struggled to get the pump cover off although eventually did and cleaned the pump basket. I also cleaned the skimmer basket today and vacuumed part of the leaf matter (there is a lot) from the bottom of the pool and emptied a load of leafs out afterwards; I'll give the floor a better clean tomorrow also. There is a Barracuda (I think) suction cleaner also although I'm not sure yet that it is properly working/moving around although I was at work all day so wasn't watching it.
It seems that the chlorine is low, free chlorine is very low, total alkalinity is non existent and pH is low. What would be the suggested treatment order/steps to improve this? I'll go look at Bunnings tomorrow although I'm thinking from a brief read that I need liquid chlorine, baking soda and borax maybe?
Any help is greatly appreciated! Cheers
