For a new 370 gallon Sundance Spa, did a new fill last night. It has ozone and UV.
My initial water balance had TA: 50 ppm and Calcium: 40 ppm.
I adjusted TA to 80 ppm and Calcium to 140 ppm. pH read 7.8 and I adjusted to 7.6.
I added 15 fl oz Boric Acid so borates were 50 ppm.
I added way too much dichlor (5 tsp) and FC was over 14.
With above settings, Saturation Index (SI) was 0.
This morning:
pH: 8 => Added dry acid
After 15 minutes:
pH: 7.4
TA: 50 ppm
FC: 8 (Lid is now open to expose to direct sunlight for a few hours)
Using the calculator, my SI is low (-0.44) with these settings (104F). If I were to adjust to TA = 80 and pH = 7.6, the SI would be balanced.
I presume with aeration and time, the pH will creep upwards. I'd appreciate advice on targets and whether I should raise TA with baking soda to 80 ppm. I expect an ongoing circle of raising TA to 80, pH creeping up, adding acid, TA dropping and being in the same place.
Thanks for any advice.
This morning:
After 15 minutes:
pH: 7.4
TA: 50 ppm
