'First-aid" treatment after a big pool party
dykes26
184
Hi All-
Any info about this product? I have a friend that swears by the stuff after a large pool party. He throws it into the pool right after all the people get out and it breaks up the sunscreen and other yuck!
Thoughts?
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
31,682
I don't know what the product is but you don't need it. Simply elevate the chlorine to perhaps 50% or even double it's normal level and that'll take care of it. Better yet, elevate the chlorine by 50% BEFORE the party and you'll likely see verylittle change in your pool at all.
JasonLion
Platinum Supporter
37,880
Pool first aid is a mixture of an enzyme treatment (which helps break down oils more quickly) and a clarifier.
Normally, adding a little extra chlorine after a pool party is more than enough. In a really extreme case, with lots and lots of extra suntan oil in the water, you might get to a point where Pool First Aid is worth using, but only if it really was extreme and you were in a hurry. Chlorine alone will clean things up, generally within a day or two.
Thread starter Other Threads of Interest Forum Replies Date
A Swimming Pool Start-up and Closing 1
M Under Construction 3
