Hey everyone. Moved into this house 3 weeks ago, and was unable to pay attention to the pool at all because of an emergency trip which i just got back from this weekend. Finally got the chance to do a full test.
I think the pool is around 8,000 gallons, give or take. It's a saltwater pool, with a hayward proseries high rate sand filter.
Salt level is 2800ppm, pool chlorinator is at 50%. (what is this, does it automatically top-up chlorine? and if so, how does it work?)
We're based in north Georgia - Woodstock area.
Ch - 4
Br - 2
pH - 7.7
FC - 2
CC - 0, maybe 0.5?
TA - pink at 50, redder at 60
CH - 100
CYA - did this test twice, it was a long, long way from the black dot being obscured. at 20 I could detect a slight darkening to the water but thats it. probably very, very low?
The previous owners left behind some chemicals - I have on hand:
Leslie's alkalinity up (is this just baking soda? it doesnt say on the packaging but the poolmath app says use baking soda)
Leslie's nophos
Leslie's hardness plus (is this just calcium chloride? weirdly doesnt say on the tub)
Granular Floc (when / how much etc should I use this? we do have lots of tiny particles on the surface and this says it helps with that)
there's a faint tint to the water color - it's not perfectly clear.
Using the poolmath app, am I correct in assuming my next steps are to purchase 4lbs of dry cyanuric acid, and presumably with it being so low it's undetectable, I should add 1-2lb first, test, and then get a more accurate number to know how much I need to add the next day?
Am i correct in thinking I should not be adding any chlorine until this is back in the 40-50 range?
Poolmath also says I need to add 15lb calcium chloride, 1lb baking soda. Presumably I can just do that tomorrow at the same time as the CYA?
The free chlorine section gives the math in bleach - am I supposed to just use regular bleach to up the chlorine level? So I can stock up on some jugs and once the other chemicals are stable, toss that in until the numbers are correct?
I've got no clue what i'm doing, trying to figure this out as I go and it's kind of overwhelming. Presumably, with some numbers so low, should i assume that we should not be swimming in this yet?
Is there anything else I should be doing for general maintenance?
Thanks!
Ch - 4
Br - 2
pH - 7.7
FC - 2
CC - 0, maybe 0.5?
CH - 100
Leslie's nophos
Thanks!
