I've been busy away from the pool this week but have a few days here now to pay attention to things. I ran a full set of numbers and they show some work needed. I have a question about the sequence of events though.
Our salt is high (4,000) so I'll need to drain off some water and refill. I assume I should do that first, rerun the numbers and then adjust the chemistry based on the new numbers? The goal is to get the pool chemistry correct BEFORE I put the new electrodes in since I feel like it was chemistry that caused them to fail.
Here are the current numbers:
FC - 5 (Pool Math App suggests I shoot for 7)
CC - .25-.5 (it was very very faint pink. I'm sure half a drop would have made the sample clear)
pH - 8.2
TA - 150
CH - 250
CYA - 50
Any other advice on how to manage these numbers and bring them in line is appreciated.
Re: my other post about weird sediment on the bottom of the pool - I'm going to use this opportunity (the need to drain off water) to vacuum that stuff to waste. I'll also then deep clean the sand filter since I'm pretty sure the drain off will drop the water below my skimmer.
pH - 8.2
TA - 150
CH - 250
CYA - 50
