I'm trying to improve the efficiency of my recirculation system by reducing the losses of the plumbing. Specifically, I'm looking at ways to eliminate traditional cartridge/sand filters since they seem to be one of the most restrictive elements in the system.
The CircuPool TJ-16 "Typhoon" Pre-Filter claims that it can effectively remove "96% of all heavier than dirt particulate down to 30 Microns, and 75% down to 20 Microns. Can capture debris as small as 5 microns." Given its effectiveness, can I completely remove the cartridge filter and use this instead?
Is there a hard requirement (based on health/safety I assume) for minimum filtration size of filters? I see that most filters are rated to 20 micron, but I'm not actually sure if this is a requirement and where it comes from. Increasing the filtration size would allow for a far less restrictive system.
