Will pumping that through my pool pump cause problems? Only small stuff would get through the skimmer. I don't know how the pumps are made.
How does the water look? Still cloudy?Worked like a charm. I just had to duct tape half of the house of to get more suction. Cleans the whole bottom in 2 hours.
I ran some water tests yesterday and nothing was way out of wack. I added some salt and bleach to get where I need it to be. From there I will dial in pH and TA.
Do I need to worry about when they stain and seal the concrete? I expect some of that will make it into the pool.
Also I just looked at the sight hole at my deep end and it's dry. Also my ground is limestone so it shouldn't move. They had to hammer to get the hole.
You could build your own depending upon needs and budget.It may be worthwhile to have a pool service vacuum your pool with a standalone rig like this.
Wen you have a chance could you post how you finally resolved it and how you would handle it if it occurred again to help others in the future..Debris is already resolved. Working on chemistry now.
Does this tell anyone if my swgc is actually doing anything?
