- Apr 2, 2022
- 802
- Plaster
- Pentair Intellichlor IC-40
I noticed today something unusual about my filter but since I’m so new I this I don’t know if it’s an issue or normal. I have an intelliflo 3HP 011056 pump and a CCP520 filter on my 9000 gallon pool. I run the pump 24/7 at 200 rpm above where my IC40 has a flow issue, with 2 hours a day set at higher rpm for skimming.
Case 1:
900 RPM
<2 psi (too low to read on gauge)
19 GPM
Case 2:
2700 RPM
9 psi (right where it was when PB started up pool)
79 GPM
When the pump is running low rpm a little bit of air builds up in the pump (maybe a few half dollars worth) which goes away when the pump spins up to higher rpm. I never thought anything of it.
But today I was thinking of opening the filter to clean out any leftover junk from construction and when i opened the reliefs valve at low rpm, air enters the filter via a gentle sucking sound and vacuum feel to the relief valve. At high rpm, water comes out. Is that normal for air to enter the filter when pump is running really low? Does that imply a negative pressure? Or just not enough flow from pump to fill the filter?
Something to worry about or just keep on learning about my pool?
Thanks
B
Case 1:
900 RPM
19 GPM
Case 2:
2700 RPM
79 GPM
Thanks
B
