- Feb 6, 2015
- 7,851
- Plaster
- CircuPool RJ-45 Plus
Below 1000 rpm, the effeciency of the motor drops drastically.Interesting - why the 1000 rpm limit?
David,When the pump speed is reduced to below 1000rpm, the vacuum inside the pump basket is dramatically lowered. Because the vacuum in the basket is much lower now, the basket lid is no longer being pushed down the way it was before, this in turn causes the o-ring to not have the same extreme sealing effect as it did before with much higher speeds.
In a closed/sealed system - no.Side thought - does that mean at low rpm of water can exit filter faster then the pump can fill it that it effectively causes a pulling effect of the water rather than a pushing effect? More like a siphon by the returns? (Which I have 6 of).
BDY,Interesting - why the 1000 rpm limit?
I would rather trust the collective experience than my own newbie judgementBDY,
The whole point of running slow is to save on your electrical bill.. In my tiny mind, I believe that once you go below 1000 RPM you are not really saving much and skimmers are less likely to be working well. I run 24/7, mostly at 1200 RPM, for less than $20 bucks a month. How much of that $20 could I possible save by running slower?
One size does not fit everyone, so you just need to set things so that they work well for you, and your pool. Most of my recommendations are based on what works well for me.
Let's say the pump uses 100 watts per hour and runs for 10 hours per day. That equals 1000 watts per day or 1 kW.
If your electric rate is $0.15 per kWh, it costs you $0.15 per day. $0.15 per day times 30 days equals $4.50 per month.
Mine says 71 watts at 1000 rpm and 1084 watts at 2700 rpm. I’m calculating 14$ a month!What Gene says above..
When I run at 1200 RPM my system reports about 196 watts. I use $20 bucks because it is a nice round number and not everyone has the same low electrical rates I have. Keep in mind that I have an older IntelliFlo and the newer ones are even more energy efficient.
The filter is ground level relative to pool so i would guess 5.5 - 6’ above water line.I don't think anyone has asked this question yet but it can explain why air sucks into the filter at low RPM. What is the height of the filter relative to the pool water level?
If the filter is fairly high relative to the pool water level, the top of the filter can be below atmospheric pressure even with the pump running. The RPM of the pump determines the pressure at the top of the filter but it is not always above atmospheric.
Since a typical filter is 3' high, that means the bottom of the filter is 3' above water level? Is your equipment pad 3' above water level or close to water level? If the pad is close to water level, the top of the filter would be about 3' above water level.The filter is ground level relative to pool so i would guess 5.5 - 6’ above water line.
