Hello All,
First time pool owner and have done a deep dive on this site over the past few months and have successfully worked through the basics of managing my chemistry thus far--thank you.
I have read the article on here about starting at a 4 hour pump run time and then increasing/decreasing based on chlorine generation. As well, I have seen some folks state they run their pump as little as 30-45 min per day.
I assume it's best for the equipment and power bill to run as little as possible. Given this, is it best to determine a minimum time and have the SWG set to 100% and only run as long as needed for surface cleaning and chlorine generation?
Does the filter and SWG need to be run daily when water temp is above 60 degrees, or can it be run less if chlorine level is maintained?
