I'd like to use my spa as a cold tub in the summer, but I can't get it to cool down! With the cover on, the water typically stays between 105-107 all summer, without running the heater. I started collecting some data on this and noticed something interesting: the water temperature increases only while the filter pump is running. I'm looking for an explanation of this. I know that every pump produces heat as a byproduct, but I'm quite surprised it would be enough to actually heat the water like this.
I attached 2 graphs showing the temperature over the last 6 days. On Tuesday night I reduced the set point from 104 to 80 and opened the cover, and by 7am the next day it was down to 80. The filter pump runs daily from 9am-5pm which corresponds exactly with the temperature increases.
The graph shows power consumption on Tuesday of 4500W when the heater was running, and 480W for the daily filter cycle. As an experiment, I'm going to try changing the filter cycle to run at night. But I really don't prefer that because of the noise.
