Re: Filter pressure guage reads 40 psi when running, normal?
FYI, I spoke with the 'start up' guy, again, keep in mind I do NOT trust him. He said that if the pump is ON at 3450, and the valve is set to 50 spa, 50 pool, that the spa will drain (even though the return is set to 100 spa). He said the Spa should NEVER be set to suck (and fully returned to) unless it is being used.
I called the startup guy with a concern about suction on the pool drains... I noted that they do not suck up sand/grit unless I push it to within ~1in of the intake. Does that sound like the intake is working at full power? This is with the intake set full pool and at 3450 rpm. He said I need to get a brush vacuum.
We took the filter apart because he said to... after figuring it all out and making sure knowing exactly how to put it together afterward, there was a couple of inches of sand in the bottom of the filter (also filling up the square drain access at the bottom). Is this normal?
Here is the stuff (some of it) he took out of the pump basket when first doing start up-
I asked the start up guy about running at 37psi and he said "Yeah, when it runs high, the psi is up"...
Again, keep in mind with all this, at the very least our returns into the spa are clogged or something because when the pump is at 3450 the jets in the spa barely have much flow coming out of them. Also, the 'aerator' pipe has no suction to it.
