I had a lot of dirt/leafs in my pool so last weekend i cleaned the filter and started sweeping and cleaning the pool. The pump pressure started at 18psi when the filter was clean and recharged. Within a few hours the pressure was up to 30psi. I turned the pump off and let the pool sit for 24 hours. The next day I turned the pump on and the pressure was back down to about 22psi. I was able to run the pump for a few hours and then it would go up to 30psi, I would shut off the pump, let it sit for a while and turn it back on. Each time the pressure would drop down to around 22 or 23psi.
Today I cleaned the filter again knowing it was filthy and full of the dirt/leafs I had sucked out of the pool. I put the filter back together and charged it. The pressure was at 18psi. I turned the secondary pump on to get the pool cleaner to start running and the pressure jumped up to 30 PSI. I figured something is clogging the cleaner line someplace but have not had time to look at that yet. I just turned the cleaner off and the pressure drops back down to 20psi. After running the pump for about 3 hours the pressure at the filter is back up to 30psi.
I have cleaned this pool and not had to rinse the filter two or three times before and the filter has never had pressure issues before.
Any ideas?
Thanks.
Any ideas?
Thanks.
