My pool filter seems to have stopped filtering. Here is what has happened so far:
0. All is working normally, pool clean and clear.
1. Algae Bloom about 1 week ago.
2. Checked stabilizer level - was low.
3. Started the SLAM process, raising the Chlorine to about 15 PPM.
4. Started noticing the PSI which usually is about 8-12, is 5.
5. I clean filter, but it's barely dirty.
6. I check water flow, and water seems to be flowing through just fine. Circulation seems normal.
7. I check paper filter cartridge, but don't find any tears or issues.
I just checked pressure by hand where water comes out into the pool and it is far lower than normal.
Does this mean there is blockage in the pipes somewhere?
I don't understand what is occurring or what I should do.
