Hi All!
Thank you for our second season of trouble free pool care. So happy I found this site when our install was taking place. Water has been absolutely sparkling for two solid seasons. WooHoo!!!
As I'm preparing to close in the next couple weeks, I pulled my filter apart today and hosed off my 4 filter cartridges. Quite a bit of crud removed--my gauge pressure only went up 2 psi through the whole season. I'm guessing it's because my filter (Pentair 320) is oversized for the pool (13k gallons). While the large debris was removed, there still appear to be some brown staining on the pleats that doesn't come off. This leads me to a few questions about cartridge care...
1. I've only cleaned the filters by hosing at the end of each season. Will I extend cartridge life by cleaning more frequently?
2. Should I routinely use a chemical cleaner, either TSP or muriatic acid?
3. How many seasons should I expect out of this 4 cartridge unit?
4. How do I know when the pleated cartridges need to be replaced?
Any help and/or information would be much appreciated. Hope you've all had a wonderful swim season!
