Fill Water Low FC, High CC
BigOrangeSpa
41
Brownsburg, IN
Hey all,
I had a quick question about the results from my test of the fill water I plan to use to refill my hot tub.
Here's the results:
FC: 0.5
CC: 1.5
TA: 230
pH: 8
CH: 250
Is it normal for tap water to have a high CC like that? Is this suggestive of ammonia? Should I SLAM after filling and getting TA adjusted?
Chloramines are disinfectants used to treat drinking water. You don't need to treat the tap water. Keep your FC at the FC/CYA levels and the CC will burn itself off.
Reactions: BigOrangeSpa
