Forgot the skimmer is here. The leisure pool is designed for one skimmer and unfortunately its sort of upwind but we get wind from several directions where I am. I asked about a second skimmer and PB wasn't sure how they would do it with spa and tanning ledge on on other end and wasn't sure a on the sides would be great and they have not installed one on the Leisure Ultimate other than the designed spot on the shell. This is our plumbing info:
Plumbing Filtration Elements (Pool)
o (1) skimmer with 2” SCH40 PVC suction line to pool equipment pad
o (2) VGB-approved main drains with 2” SCH40 PVC suction line to pool equipment pad o (3) directional returns with 2” SCH40 PVC return lines to pool equipment pad
o (5) Jandy Never Lube valves for above mentioned lines
Plumbing Filtration Elements (Spa):
o (4) spa jet combo air/water returns with choice of rotational, massage or twin-spin internals o (1) directional return with 2” SCH40 PVC return lines to pool equipment pad
o (3) Jandy Never Lube valves for above mentioned lines
He said with auto-cover closed during evening and when not swimming circulation should be good and skimming should be good. The only thing I worry about is the comments people have made if your skimmer goes down your sol with only one.
