Been following and using the TFP method since day one of new pool....and though I got it.
However in reading a few threads I am not so sure. Specifically do I need to worry about my "low" CH.
Water is TFP Clear of course...
I have a fiberglass pool, with a heat pump
FC - 4.0 (end of day after a ton of swimming) adjusted the Stenner for a slightly higher target
CC - 0
pH - 7.4
CYA - 50
TA 110 (always creeps up, but seems to stabilize around this number, know I should drive pH down and aerate at some point)
CH - 50
Do I need to worry about the CH ? If so for my pool, is the 220-320 range what I should target ?
Thanks in advance!
CC - 0
pH - 7.4
CYA - 50
CH - 50
Thanks in advance!
