I’ve tried everything possible to lower my combined and nothing worked. After talking to a bunch of PB, water testing, etc only way was a to drain it. Obviously I’m not doing a full drain and risking damage. I lowered the pool to an inch below the skimmers and closed the valves. I’m am draining from the main drains in the deep end on the bottom of the wall threw a waste pipe after the pump in between the cartridge filter. On the opposite end I have two hoses going into the pool. I have the valve draining the pool at the exact same rate as the water going in. 17.6k gallon pool I’m looking around 35 hours for a full swap then I’ll top back off? Sound about right??? When I’m don’t I will vacuum the bottom and clean the filter. I hope this gets rid of the CC!!! What should be my first step getting the PH correct then adding chlorine then the salt ?
