We are in the planning stages of our first pool. We have done a lot of research on the forums but now need some final thoughts on equipment, design and overall thoughts on anything we may not be thinking of.
We are going with the Latham (Viking) Fiji. A freeform fiberglass pool ranging from 3'6" to 6' with a tanning ledge, 15'x34'. We are considering the "night sky" shell color but have not seen any real photos of the shell with or without colors. I am also not sure whether we will get the crystite (G3) that has more sparkle or classic (G2) "no sparkle". Any one have any experience or recommendations as to whether the G3 colors are worth an upgrade?
Our rough design has patio space on the south (bottom in the drawing) and about an 18" terrace on the north (top side of the drawing). The pool is going between our existing patio and pavilion and the existing shed on the north side of our property. The equipment pad will be right against the house to the right of the smaller shed (garbage can storage). So the plumbing runs will be very short. We plan to put 6' privacy fence around the pad to hide it all.
Would love any thoughts on the design and layout.
Our builder does all Pentair equipment and my thoughts are as follows. I believe our pool is about 12,000 gallons as a reference and we are in southwest OH so our season is late April to Mid/Late September:
Pump: Intelliflo VS - not sure what size
Filter: Thinking cartridge (CCP) or DE (Quad DE) also not sure on sizing. I know we want to oversize it but not sure what oversized is for our pool. I don't really want to deal with backwashing since we would be backwashing nearly right onto our pool deck. Assuming we size our filter right we will likely only clean the filter once at the end of each season.
SWG: IC20 or IC40 not sure if the IC20 is big enough
Automation: leaning towards the Intellicenter with the IC40 load center. I have read that if you get the right Intellicenter package it has the SWG load center and the IC40. I am not sure you can get the package with an IC20 if that is what we need for our pool size.
NG Heater: Master temp - size?
Lights: builder says the package comes with 2 lights but not sure which ones specifically. Are the intellibright 5G the "best" Pentair LEDs?
Features: we are planning on two waterfalls in the concave curves on the north side (top) of the pool. The one will be over the submerged seat. Is that a good idea? We kind of think it might feel good to sit under but will it be annoying? Is it best to put the waterfalls on their own pump? That way we can turn them on or off through the automation regardless of the main pump speed.
Returns: I believe 3 but not exactly sure on those details yet.
Skimmer: 1 skimmer
Drain: 1 main drain
Extras:
Extra outlet near the equipment pad for robot or other needs.
Light over the equipment pad
spigot near equipment pad
Anything else you wish you had or found to be helpful?
Skimmer: 1 skimmer
Drain: 1 main drain
Extras:
