Fiberglass Exposure from a Little Giant APCP-1700 Cover Pump?
hhtat
4
Austin, TX
We've a APCP-1700 that's about 1.5 years old now. Been through one summer down here in central Texas. Went out to clean the pool cover yesterday and came back in with pin and needles feeling all over my right hand. Checked with duct tape and yet, a bunch of fiberglass. Went back and checked everything I touch and the pump housing and handle has glistening in the sun. Checked it with tape to and it pretty much covered the tape.
I searched all around and didn't find any mention of this on Amazon, here or elsewhere on the web. Did I get one from a bad batch or maybe overlooked something about care or sun exposure?
Also - any recommendations for a cover pump? Honestly, really like how stable this one was except for this recent issue...
I don't think that it is fiberglass.
Technical Support Team: Help is a phone call away.
With decades of collective industry experience, our team is made up of real people, offering real answers, in real time.
For answers to your water systems questions, contact our technical support team by phone at 1-800-701-7894 or email at [email protected].
Tel: 844-250-4982
Fax: 260-827-5800
[email protected]
Materials of Construction​
Pump Base MaterialPlastic
Pump Body MaterialPlastic
Discharge Head MaterialThermoplastic
Impeller TypeSemi-open
Impeller MaterialNoryl
Motor Shaft End - MaterialStainless Steel
Check ValveNo
Discharge MaterialThermoplastic
Intake Screen MaterialThermoplastic
Seal MaterialCarbon Ceramic
92395: POOL COVER PUMP
Thermoplastic Construction.
FEATURES
2100 GPH @ 0’
Thermoplastic construction with built-in handles for ease of transport and installation
1” NPT discharge
3/4” garden hose adapter
Activates in 1-1/2” of water
Pumps down to 3/4” of water
Large base design for added stability
Bottom screen removes easily for cleaning
Internal automatic vertical float switch
Hermetically sealed, oil cooled motor for long pump life
Clog resistant impeller
Motor is thermally protected with automatic reset thermal protector
Energy efficient split capacitor motor. Lower amp draw, runs cooler, lasts longer
Stainless steel motor shaft
Carbon/ceramic/stainless steel mechanical shaft seal
Upper and lower permanently lubricated ball bearings
Stainless steel fasteners
Acceptable for indoor or outdoor use
Compact, lightweight design is easily portable
Every unit is 100% pressure tested
I have been using that pump for many years and have never seen any fiberglass pieces.
I would look elsewhere for the fiberglass source.
I think water washed the fiberglass from somewhere else onto the pump.
What filter do you have? Filter housings are fiberglass and can breakdown.
Any construction happen around your property?
Thanks for the info, didn't realize manufacturers published material information! Will have to give them a call to ask when I get the chance.
Here's a video of the fiberglass:
It definitely looks embedded in the plastic. It's exposed everywhere the sun has weathered away. Did not find fiberglass anywhere else nearby like the power cord, hose and warning stickers. I'm puzzled.
The people who answer questions are volunteers.
If you find the site to be a good resource, please consider making a donation to help support the site.
Thanks.
I just did a search and found this thread. I am on my second little giant. I picked it up to clean the weep hole and wound up with fiberglass shards in my hands and forearms. I just purchasedIMG_3581.jpeg it last year. It is most definitely shedding fiberglass or something like it. The last one did not do this. My Wayne pump doesn't do this. Something seems off. So I searched and found this thread.
  • Wow
Reactions: JamesW
