- Jul 12, 2020
- 22
- Fiberglass
- Jandy Truclear / Ei
I found this document online about PH and Calcium levels for Leisure pools fiberglass maintenance and is sort of opposite of TFP and what is mentioned on the forums:
So what should we follow? I have it currently at 290 ppm and TA at 70.
pH 7.2 to 7.4 • Total alkalinity between 80 to 120 part per million
Calcium naturally occurs in water. Different areas of the country have higher and lower levels of calcium in the water. The higher the calcium concentration in the water, the more prone the pool is to calcium leeching. When the pH is maintained between 7.2 and 7.4 the calcium is balanced in the water. Calcium levels should be maintained between 80 – 120 parts per million. When the pH rises above 7.4, calcium begins to leech out of the water and cling to the swimming pool surface. The higher the pH is allowed to go, the more pronounced the calcification can become. Obviously the problem occurs more often in areas with higher natural concentrations of calcium in the water.
All that is required for calcium to fall out of solution creating a layer of scale is a pH of 7.4 or higher and calcium hardness over 150 parts per million. The higher the levels, the more pronounced the problem will be. The current guidelines being used for adding calcium to water are based on concrete pool guidelines. There should really be no reason why you should add calcium chloride to your water for a Leisure Pools® swimming pool. Please be aware that many pool stores, mass merchants, and mobile service companies do not know how to correctly care for fiberglass pools.
