FC Drop
What is your CYA?
An FC drop of 2 ppm or so this time of year is possible. Though it will be reducing as the sun angle drops.
I use 8.5% bleach and try to keep at FC levels of 3 or 4, but we've had non stop rain the last week so at one point the FC had gotten to 0.
I use the test kit recommended on this website.
I have chlorine tablets that I use if I am going to be away and unable to test, but haven't used them in a while.
Great. Please add your test kit information to your signature.
You might want to use a couple pucks to raise your CYA a touch. No more than 10 ppm.
Take care.
If your CYA is low and you've recently had very low chlorine, you'll probably go through chlorine faster. Get the CYA up and maybe operate at higher FC level for several days and you'll probably see an improvement in stability of your FC level.
