- Nov 2, 2021
- 31
- Fiberglass
- CircuPool Edge-25
I have a new (1.5 years) Fiberglas pool. I had been using tricolor tablets until I found this site. I had been having a hard time keeping any measurable FC this past summer. I shocked the pool with powdered shock. Since then I had an acceptable FC level. I stopped using the chlorine pucks after I read the info on this site, but my chlorine is still high. I purchased the TF 100 test kit in late September and tested my pool. My FC was very high and ph was 6.8. The attached photo shows the high chlorine. I haven’t been able to test the water since the middle of October due to hip replacement and fracture. I tested again today and this is what I got:
FC. 26
CC 0
CH 250
TA 110
CYA 140 (using the half pool water, half tap water x 2)
These are the same results I had a month ago. The only thing that was added to the pool in that month was 5.5 inches of rain. The pool manufacturer says not to drain the pool or the warranty will be voided. Also the ground water in central Texas can cause the pool to come out of the ground. My pool does need water added at this point due to evaporation. Level is down about 3 inches from top of skimmer opening.
Any suggestions to drop the FC and raise the ph?
Thanks
FC. 26
CC 0
CH 250
TA 110
Thanks
