- Jun 23, 2024
- 15
- Plaster
- Hayward Aqua Rite (T-15)
I may be new to this forum but not to the Goldline saltwater generator system. I have an electronic tester and I double check it with Leslie Pool store. My cell will generate chlorine until the ASR drops below 2800 then I have to set it back to the actual salt reading in the pool. I'm looking for someone with technical knowledge of how to bypass the ASR sensor just like the temperature sensor can be bypassed with a resistor/variable.Hi, Tell me how you're testing your salt to know the Acurite system is false.
Okay, then I need to know how to bypass the voltage/amps which Im pretty sure is going to be a capacitor or resistor. I need to know which components are controlling this value.Welcome to TFP.
There is no salt sensor on the Hayward Aquarite. It is a calculated value based on volts and amps of a new cell.
T-15 cell works just fine as long as the ASR is in the operating range. But it is dropping below operation range (2600) every couple days and I have to recalibrate. I need someone with technical knowledge on how to bypass ASR so I can manually set it I have to.To get the performance of the cell, divide the instant salinity by the actual salinity. If the ratio is less than 75%, it's time for a new cell. For example, 2,000 (instant salinity) ÷ 3,600 (measured salinity with a test kit)=56%. Check the cell and clean it if necessary. If that doesn't work, it's time for a new cell.
You can change the cell type to a smaller cell to make it work longer.
What cell do you have?
What cell is selected in settings?
Basic AquaRite Diagnostics.
This is the basic information we need to know in diagnosing a problem:
- Report all diagnostic readings when you..
- Move the switch from auto to off and check all of the readings.
- Move the switch back to auto and recheck the readings.
- Move the switch to off for a minute and then back to auto and recheck the readings.
- What are the first seven characters of the cell and box serial numbers?
- What is the actual salinity and how are you measuring it?
Hayward Aquarite SWG - Further Reading
www.troublefreepool.com
Has anyone figured out how to bypass salt sensor on Hayward Acurite system?
T-15 cell generates chlorine when ASR is maintained. I reset the instant salt reading and immediately locked the reading when the relay clicked at 3800ppm. It will generate for a while, then over time the salt reading drops and the check salt light comes on and the salt generator stops producing. Anyone have any ideas?To get the performance of the cell, divide the instant salinity by the actual salinity. If the ratio is less than 75%, it's time for a new cell. For example, 2,000 (instant salinity) ÷ 3,600 (measured salinity with a test kit)=56%. Check the cell and clean it if necessary. If that doesn't work, it's time for a new cell.
I have been testing with digital tester and Leslie Pools for several years. Readings are very close to each time. Actual reading is just around 3200.Hi, Tell me how you're testing your salt to know the Acurite system is false.
I think your cell in is the process of dying, ora t least one side of the plates has prematurely worn faster than the other side. Rather than resetting every day, it might be better to change the t-cell setting to T-9, then t-5, then t-3 (if your firmware is r1.50 or higher) so salt readings still fall within Hayward's desired range. Of course,you will have to either increase the duty cycle and/or the pump run time to offset the reduction in hourly chlorine output.T-15 cell works just fine as long as the ASR is in the operating range. But it is dropping below operation range (2600) every couple days and I have to recalibrate. I need someone with technical knowledge on how to bypass ASR so I can manually set it I have to.
Sir...Like I said, T-15 (R1.40) cell works fine and continues to generate the proper levels of chlorine. Why on earth would I replace it. Are you insinuating there is a sensor in the salt cell that calculates ASR and this is the reason why the reading drops below 1900/below, when actual is 3200.I think your cell in is the process of dying, ora t least one side of the plates has prematurely worn faster than the other side. Rather than resetting every day, it might be better to change the t-cell setting to T-9, then t-5, then t-3 (if your firmware is r1.50 or higher) so salt readings still fall within Hayward's desired range. Of course,you will have to either increase the duty cycle and/or the pump run time to offset the reduction in hourly chlorine output.
Is this volts and amps?26.7 / 1.85
No but you can spoof it:Has anyone figured out how to bypass salt sensor on Hayward Acurite system?
A T-15 should have amp levels 2x higher than that (~6 amps). In the link I posted above, the cell that was failing was less than half that an yours is even lower than that so it is even further gone than the one I had.
- Move the switch from auto to off and check all of the readings. 31.4 / 0
- Move the switch back to auto and recheck the readings. 26.7 / 1.85
- Move the switch to off for a minute and then back to auto and recheck the readings. 26.5 / 2.63
First number is voltage / second is ampsIs this volts and amps?
Most likely the cell is dying.
The salinity is calculated from the performance of the cell.
Poor cell performance = low salinity reading.
What are the first 7 of the cell serial number?
