I searched but couldn’t find an answer to this so I’m asking.
I have an intellitouch i7+3 that is controlled with Screenlogic2. Without writing a book about how I got here I’m at the place where I need to confirm if this board is bad.
So I want to do a factory reset and reprogram to see if my current problems go away. I’ve spoken to 2 field reps and 1 tech support. I’m telling you that to avoid the “why what’s going on” novel length answer. I didn’t get here on my own so just trust this is what needs to happen.
The tech support guy told me I could do it with screenlogic but it would be easier with a laptop. Unfortunately the only computer I have isn’t running an OS from the stone age so I can’t install the SL software. So I only have SL Access and I know there’s no real advanced functionality with the Config app like there is with a control.
So 2 big questions. 1. Is there a sequence of button pushes that will wipe that board to factory settings? I don’t have any thing else to connect to use the erase eeprom function.
Next big one. If I can successfully wipe that board can I then pair a screenlogic2 to it to reprogram it. I’ve setup a dozen screenlogics but never to a fresh board. So I don’t know what I don’t know about this process.
Thanks in advance for any insights you may have.
