Tried to remove the faceplate for a Proline 93084 which is almost 15 years old. The skimmer was cracked. Outside gasket was leaking.
The inner gasket, proline 93084 was not a butterfly gasket, seems to be very well stuck. I pulled but the liner seemed to tear at the point I pulled.
Anything else I can use, it seems like the gasket used was not a pvc type instead a rubber version, to remove this plate and gasket.
Right now I am using a butterfly gasket with the gasket between the wall and the liner on the inside.
