Thank you in advanced for all the info this site and members provide!
A couple of weeks ago I started noticing the water was a little cloudy (could still see bottom) and there was a small amount of green algae around the skimmer, light and border tile. I didn't want this problem to grow so I decided to get ahead of it with pool season only a few months away. In addition the SWG keeps showing low salt despite the salt test showing within range, not sure if they're two separate issues or not. My pool is a small fiberglass saltwater pool at 6k gal. The FAS/ DPD test initially showed FC at 1ppm and extremely high CC at 25 ppm. Other readings are in range or really close, TA 60, CH 250, CYA 50, salt 3800. After research, I decided to SLAM the pool and maintain a shock level to get rid of the CC.
I did do a Jacks Magic iron scale treatment with #1 and #2 products mid November, followed step by step and worked great at removing the stains I had on the pool. When I did start re-chlorinating I only turned the SWG back on which I am still learning and realize now I probably never got the FC up high enough with just the SWG. I am also unsure if the stains were metal, scaling or unknown but the combo of the #1 and #2 were the only thing that would lift them.
I'm on day three of SLAM and I've been using liquid chlorine and maintaining around 20-22ppm FC, checking 2-3 times a day however the CC continues to rise and is now closer to 30ppm. Also my FC is being consumed each time I've checked it dropped from 20 to 4-5, although it only dropped to 11 from last night to this morning.
I spoke to Jacks Magic rep and he says this wouldn't cause the high CC after this much time. Should I trust his advice and the test and stay the course? Should I replace the water? Any advice is greatly appreciated.
