- Feb 17, 2022
- 399
- Plaster
- Pentair Intellichlor IC-40
Not sure if this should be here or under everything else, please move if needed.
I recently had a failure of the bypass valve in my Pentair MasterTemp 400 heater. A potential reason as to why this occurred was there was to much flow going through the heater according to some posts (here New Construction Started - Willis, TX (north of Houston)) I have found on this forum, but I have also found contradicting posts stating the bypass is capable of handling a high flow rate from a VS pump (can't find the posts).
I was hoping to get clarification on the necessity of the bypass as I will hopefully be having my heater repaired soon and in the process want to install the bypass if its needed.
