Hi All,
I'm currently building a custom pool controller using some relays, and I'm trying to figure out the best approach to the Max-E-Therm 400 that I have. I'm reading the documentation and I can do either a 2 wire or 3 wire install. The 2 wire requires the use of the firemans switch (from which two wires then go to the external control interface) and this part gets confusing to me, the 3 wire does not? If it does not then can I just apply 24v AC to the spa side or pool side? If thats the case then would the heater then just use whatever the max is set to for that type or would I just need to just turn off the heater when the pool or spa temp hits a certain temp?
If anyone has any idea its greatly appreciated.
Jon
Jon
