Experiment with one-micron filter media
kotpool
Active member
Nov 6, 2017
44
Ojai CA
After the 2017 Ventura County Thomas Fire, it's trivial to complain about ash in the pool compared to the lives lost and homes destroyed. But here goes anyway: We came home after evacuation to find our neighborhood standing. But ash was everywhere and we wore face masks for weeks afterward, sometimes even inside the house. Sweeping outside would only move it around and blowers made it worse. A pop inside the vacuum cleaner was the HEPA bag exploding from overfill, just from vacuuming the front porch. The pool was a mess, of course, and the dark bottom wasn't from colored plaster. After a few days I vacuumed the pool. It looked good for a few hours and I was surprised the differential-pressure gauge rose only about one psi. But the next day the bottom was pretty dark again. I removed and hosed off the filter cartridge and it was dirty but not as much as I thought it should be. I vacuumed again, and the next day the bottom was dark again but not as dark as the previous iteration. Windy Feb/Mar whipped up ash clouds several times, even after the rains. Each vac session cleaned up a little but some (most?) ash got though the cartridge pores. Instead of installing a DE filter or a Slime Bag or Duda Diesel Bag, all of which, I've read on this site, would catch the fine particles, I though I'd try an experiment by wrapping some one-micron filter media (see below) around the housing's core. You can see pictures at https://www.flickr.com/gp/115393210@N03/wfH28N
It seems to have worked pretty good but I think it was more work than the slime-bag-type solution. After vacuuming with the one-micron media, I replaced the original cartridge. Bottom seems cleaner so I think I've captured much (most?) of the ash (until the next wind event.) I was surprised that even with the one-micron media, the pressure gauge was only at 4psi, same as with the cartridge, and it did not rise during the vacuuming. I was able to clean the one-micron media pretty good so I can think I can use it again if I feel like it.
Duda Energy 72" x 36" polyester one-micron $24.29 total
Just offering this episode FYI as my "experiment with one-micron filter media."
Hey I have the five Micron Duda Diesel bag, and have been advocating it all over this forum for water clairity.
How was your experience with the one micron? Was water able to pass through it reasonably without causing too much psi back pressure on the filtration unit?
Nevermind you answered my question I didn't see the first post. I'm still curious how much the pressure will go up if I was to filter out algae at 1 micron?
I was very surprised that the back pressure was no higher for the one-micron media as for the standard cartridge, which I believe is rated at ten-micron. I only did one vacuum session with the one-micron media, so maybe after a few more vacuumings it would build up more back pressure. But the pictures indicate that it certainly filtered a lot of the black ash. This was a qualitative, not quantitative, experiment as I did not take detailed notes and measurements like my high school science teachers would have expected me to if I wanted a good grade.
