I just moved into a house which had an 8'x20' Modpool with a Fastlane Swimjet from Endless Pools installed about 18 months before we purchased it. Unfortunately the bolts holding the window had some rust and upon closer inspection I found some rust spots in the container wall near the window bolts (see attached photos). Are there any Modpool owners who have experienced this?
After contacting Modpools support I learned the warranty does not transfer from the original purchaser and they suggested some rust is not unusual although they did say they expect the liner to last 8-12 years. Since the pool was professionally maintained I was a bit frustrated but I really just want to get the pool back to prime shape for regular use and they suggested I drain the pool, patch the rust spots (as per a YouTube video they've created) and touch up or completely paint the inside.
Modpools provided the materials to re-do the liner. The paint is RhinoSeal HP from Rhino Flooring. Does anyone has experience working with this paint or has undertaken the job of repainting a container pool and has any suggestions or tips?
thanks,
chuck
thanks,
chuck
