Hi,
Looking for some help as I'm putting in some low voltage lighting in my backyard and would like to use the ET8 to automate the lights.
Using AUX 4 relay on the right hand side. Planning on using the GFCI power outlet on the power box.
I ran the another wire from the hot on the outlet to the relay on the first input (left side) then figured the return power would be the 3rd out. but its not working can you help with the wiring?
Maybe I'm doing this all wrong any help will be appreciated.
Thanks!
Thanks!
