I've got a Hayward T-Cell-15 with a Hayward Pro Logic panel. Both are original to the pool (which is five years old).
I've been getting intermittent "low salt" readings on the panel but chlorine production has seemed normal so far this season so I figured that the readings were the result of uneven distribution of salt in the water after rain storms (the alerts went away within a few hours each time they came up).
Yesterday I started seeing a message that says "chlorinator off - test salt level" so I added 40 pounds of salt. I also cleaned the salt cell by soaking it with a 4:1 solution of water and muriatic acid. This morning the message was still there so I used my drop test to test the salt level and it's 4000 ppm (ugh -- that will teach me to believe the panel rather than testing first!).
What does this mean? Is my salt cell failing? Is there a problem with my panel? What are my next steps? Bleach is still in semi-short supply around here so I want to act fast to solve the issue before I have a mess on my hands.
