- May 16, 2021
- 103
- Plaster
- Jandy Aquapure 1400
Can you leave a plaster pool uncovered without water in it throughout the winter without it damaging the plaster? My plan is to replace the coping, tile and pool decking, along with reengineering plumbing, over the winter and I can't do that without leaving the pool empty. I did have a thought about covering the pool with the mesh cover, and then putting a house tarp over it , in order to protect the plaster from sunlight, if that is going to damage the finish over the winter. We will also be acid washing the pool and then polishing the plaster when finished. Will that bring back the original color of the plaster and remove the calcium buildup that has developed over the last 2-3 years?
