First, has anyone EVER opened their EasyTouch cabinet without almost losing a finger from the industrial strength latches? Those things could launch a small animal into orbit.
Second, I'm trying to filter my spa once per week just to move water through the pipes. I have the schedule as follows:
When 8:15am comes around, the system starts filtering the spa, but the heater comes on, even though I have Heat Command set to Off.
I've also tried setting Change Heat Set Point to a really low number, like 55, but when I try that, the valves set themselves into Spa mode, but the filter doesn't turn on (nor the heater).
Is there a way to schedule the valves to be in spa mode, the filter to run, but have the heater turned off?
Thanks!
Thanks!
