First timer, all-time idiot for sure. Moved into this home recently and decided to switch to TFP liquid chlorine method, etc. Used TFP method to drain and replace at the same time thousands of gallons to lower CYA to appropriate level. Bought a dozen gallons of liquid chlorine, and in the mess of a garage in the process of being arranged, grabbed windshield wiper fluid instead of the new chlorine. Earlier today I poured in three quarts of the windshield wiper fluid. Discovered the error this evening when I went to check the chemistry.
Of course I am horrified as well as embarrassed, but I assume someone on this forum can help me. I know how toxic windshield wiper fluid is, and I assume I should not run the pump or put any more chemicals in the pool at this point. I assume the entire pool and spa should be completely drained and refilled. The problem is, the temperatures here in Texas are more than 100° at present. I wonder if there is some service that would pump all the water out of the pool quickly in the morning or evening, and then replace it quickly as well.
Thank you for your help.
