Hello, I discovered this weekend that I have a broken bond wire on the handrail anchors. I have a cut on my hand and when I grabbed the handle with my feet in the water I got a slight shock. I ran a temporary wire from the bonding loop to the hand rail and the shock did not exist. So now I have to figure out a way to install a new bonding wire to the anchor cast in concrete. The anchor is about 5 feet from the edge of the concrete so not sure if I can fish the wire under ground to the anchor. Once I diagnosed it to the be a bad bonding wire I started trying to figure out where the electrical leak is coming from. I finally killed all power to the house by tripping the main house breaker. My main breaker for the house is mounted directly beside the power meter. With everything off I am still getting the leak in the pool. Is it common for underground power to have a slight leak? If it's leaking before the meter, would it be the power companies responsibility to find and fix? Just looking for suggestions on what my next step should be? First thing is getting the bonding wire fixed!
