Electrical hookup question
May 23, 2018
3
Denver/CO
Fiberglass
CircuPool SJ-40
For the record -I hate electrical questions on forums but this seems simple... I am replacing an Intelichlor swg which had an outlet plug for power source for a SJ35 Circupool unit that needed to be hard wired. I’m adding a Internet timer to the mix (swg & pump)... do I/can I hook both the pump and SWG to the same breaker?
Thanks
Thanks
What pump do you have and what AMP breaker. My 3HP IntelliFlo will be on a 20 and only draws 13 so it can easily handle the SWG sipping peanuts from the same legs. Most situations can as similar but we’d need to know your exact specs.
Have a 1.5 hp intelliflo pump on 20 as well- the swg can be either 220 or 110
Depending on the specific model it’s around 11.5-11.8 max draw so from an electrical standpoint it can handle the SWG no problem on a 20 amp breaker, If your local code allows it.
Reactions: 10KsaltH2O
