Ret,
I don't see why you can't add an additional pump... *See below....
The EasyTouch can control 4 valves.. Two are used for your Spa/Pool switching, so that gives you two more if needed.
Most pool service companies, 'look' at your pool as they drive by... You will be lucky if they stop, and for sure they will not be cleaning your water feature bowls..
