I am looking for input on an electric pool valve system. Here is my dilemma. We NEVER use our spa and here is why. Once I have my manual valves for pool/spa suction/return set to where everything is working as I like it, it kills me to change it. The valve adjustments are so finicky, that literally one incredibly small tooth adjustment left or right, significantly affects skimmer flow and pool clearer output. Now times these adjustments by 2, on both the in / outflow. I even have gone as far as marking the correct position with a paint pen. Even then, due to the width of this mark there is a margin of error.
How accurate are the electric actuators. Do they have the same level of adjustment as the manual? If so, when switching between pool and spa, how accurate is the return to previous function?
If this is a viable solution, based on my pictures attached, what would be the recommendation on proper system and parts to purchase?
how difficult is the installation. I am extremely comfortable with DIY items.
thank you in advance
