Yes, at high FC the TA test goes from blue to yellow instead of from green to red. You can add more sodium thiosulfate drops (R-0007) to the initial water sample to neutralize the chlorine. If you can see the transition in color, the test is still valid.
The TA indicator dye is a mixture of bromocresol green that goes from blue to yellow and methyl red that goes from yellow to red. So when both dyes are active you go from blue+yellow=green to yellow+red=red. High FC levels react with the methyl red dye leaving only the bromocresol green dye that goes from blue to yellow.
